OK I JUST GOT SHEARER IN FRAMES AND IM SENDING MY CYLINDERS TO FAST TO GET A DRAG PORT, IM READY TO ORDER UP A SET OF CARBS. IVE DECIDED AFTER TALKING TO JEFF THAT 33'S ARE GOING TO BE BEST FOR ME. SO WHAT IS THE DIFF BETWEEN PJ33'S AND PWK33'S
THANKS AGAIN GUYS FOR YOUR HELP!!!
Pj' come in 34's or 36's PWK's come in 28mm, 33mm, 35mm, and a couple larger sizes.
The pwk is a newer design. PJ's will get the job done, but it is just an older carb. The slide in the pj's is a oval and is thicker compaired to the pwk's D shaped slide. The idle is set on the pj's bt turning the choak knob, pwk's are set by a screw that lifts the slide.
I switched from pj34 to pwk33 and haven't looked back.
Why not go with pwk 35's if your building a drag banshee. A drag port doesn't have a great midrange, why try to save something you don't have? If your concerned with midrange then maybe you should rethink the drag port.
I have a dune ported 4mill from fast running pwk33's and cpi's. It hauls the mail.
PJ's are a biatch to tune in my opinion!! I can never seem to find two that are the same!! I have ran 33, 35, and 39 PWK's and love em!! I wouldnt waste the time or money on the PJ's!! PWK all the way!! I have a set of 39 PWK's set up for gas that I ran on my dune ported 421 and they were awesome!! I switched to alky so I am running lectrons!! But, I still have the 39's and might sell them if you are interested!! They came from Jeff about 1 1/2 years ago and probably only have about 20 hours on em!!
Let me know if you are interested!! Just my .02!!
Zac
Zac
get the pwk's they are a better carb
