bbcmudtruck Posted September 9, 2009 Report Posted September 9, 2009 can somebody measure the clutch rod ball with a pair of calipers and tell me the diameter! My son found a ball bearing on the shop floor and it looks to be about the same size... The one he found measures 11mm. Quote
old roost Posted September 9, 2009 Report Posted September 9, 2009 can somebody measure the clutch rod ball with a pair of calipers and tell me the diameter! My son found a ball bearing on the shop floor and it looks to be about the same size... The one he found measures 11mm. I get home in 2 hours i will measure the ball bearing for you, that does sound about right though. Quote
bbcmudtruck Posted September 9, 2009 Author Report Posted September 9, 2009 Thanks for you help! I hope its not though.. The clutch feels and works great though, I have ran about a tank through it. What would happen if I rode it and didn't have the ball in there? Quote
portingjunky Posted September 15, 2009 Report Posted September 15, 2009 Thanks for you help! I hope its not though.. The clutch feels and works great though, I have ran about a tank through it. What would happen if I rode it and didn't have the ball in there? you would now if the ball wasn't in there. you would of had to make a huge adjustment to the clutch cable. but if the ball isn't in your rod will get real hot and weld its self possibly. ive seen a rod weld to the ball before because the ball couldn't move freely. Quote
