1. Drain oil
2. Pull water pump cover off
3. Drain Coolant
4. Pull Clutch cover off(There is a coolant nipple attatched to the clutch cover that kinda holds it on, but just pull evenly and you'll be fine)
5. Remove the circlip on the back side of impeller
6. Put new impeller back in just how the old one came out(Probably a good idea to change the plastic gear while you're in there)
7. Put everything else back together the order taken off, fill back up with fluids, done.
Should take maybe a half hour
Edited by stokes77
Same as above, you may want to change the water pump seal while yur in there, too... They do go bad so if you have everything apart just do it now.
