1/8 mile my best was like a 9.2 at 72mph i ran that with good jetting, reeds, stock cages, t5 pipes pods stock carbs and a unmilled head oh and the clutch was slipping a little.
now i have dropped the front sprocket 1 tooth. have ported cylinders mx hardcore port, 34mm carbs pods, t5's milled stock head. stock cage same reeds and 34mm carbs. new clutch however it did feel like it had a little more torque like it wanted to lift the wheels up easier than before.
but after a few runs it started running shittier, "leaning out" pulled fuel line off and nothing coming out of tank but i had gas in tank, i got home pulled the tank off and the petcock had look like packing material around the reserve filter on the petcock i cleaned the tank and have it back together but i can't ride it around where i live...
rite now i'm running 148 mains, dunno about pilots whatever were in it already.
what do you guys think? i should have a boss intake and new v force 3 reeds in the mail they should be here in a week in an a half
it doesn't sound like it's winding out up top much could this be the port?
even when it leaned out and ran shittier it didn't pick up. it got worse. also, do you think 2 or 3 runs in the 1/8 was enough to do any damage to pistons when it leaned out?
and do you think my time will pick up any with the larger sprockets?
