cudaz101 Posted August 31, 2009 Report Posted August 31, 2009 Doing a rebuild and Im going with a diff setup but would appreciate a ballpark estimation what Im gonna need for domes and carbs/jet setup. This is what I will end up with. Woods Port on Stock Cyl +4mm crank 75MM bore Forged Pistons FMF Fatties Custom Air Clean setup (K&N) Cool Head Ricky Stator Plate +3mm adv. Im on trails and open ride. Would like to get away with pump gas. Thx in advance. Ive been out of the game for awhile. Lookin forward to gettin back in. Cheers!! Quote
locogato11283 Posted September 1, 2009 Report Posted September 1, 2009 yo bro, you sure about that 75mm bore?? id run no smaller than a 33mm pwk on that setup. if you wanna run pump gas you better keep the compression down around 150. youll also need to watch it with the timing at +4. in all reality, youd gain a lot more by going ahead and running at least 50/50 pump/race fuel.. you can bump the timing up with no worries and get the compression up around 170. Quote
cudaz101 Posted September 2, 2009 Author Report Posted September 2, 2009 yo bro, you sure about that 75mm bore?? id run no smaller than a 33mm pwk on that setup. if you wanna run pump gas you better keep the compression down around 150. youll also need to watch it with the timing at +4. in all reality, youd gain a lot more by going ahead and running at least 50/50 pump/race fuel.. you can bump the timing up with no worries and get the compression up around 170. My bad...65MM bore...75 would be nice tho...lol What octane/grade race fuel. Like av gas 110 lowlead?? Thx much Bruh!! Quote
Snopczynski Posted September 2, 2009 Report Posted September 2, 2009 I recommend with the stroker setup running machined coolhead domes. Probably run 160psi compression on pump gas. I recommend a different pipe setup for low-mid though. The fatty is more of a mid-early top end pipe. Quote
