04trinityshee Posted August 29, 2009 Report Posted August 29, 2009 am i gonna have any trouble with everything going together good......i didn't know if i had to have an aftermarket cover or not Quote
LiftdT4R Posted August 30, 2009 Report Posted August 30, 2009 Nope, everything should go together just fine. With the stock parts assuming everything is in good shape. It is nice to do a quick drain coolant plate at the same time, but not nessiscary. It has an extra hold and plug tapped into it so you don't have to waste a gasket everytime you change coolant. Quote
flyRTby Posted August 30, 2009 Report Posted August 30, 2009 I recently bought a billet impeller.. before and after i installed it i noticed the impeller is real close to rubbing on the plastic housing around the impeller.. is this normal? like i said before(with the stock plastic) and after( with the billet) it seemed close. never had a issue i'm just replacing it for insurance purposes.. thanks.. Quote
LiftdT4R Posted August 30, 2009 Report Posted August 30, 2009 I recently bought a billet impeller.. before and after i installed it i noticed the impeller is real close to rubbing on the plastic housing around the impeller.. is this normal? like i said before(with the stock plastic) and after( with the billet) it seemed close. never had a issue i'm just replacing it for insurance purposes.. thanks.. Yes, there is hardly any clearence, its that way on almost every Banshee Ive worked on. Normal... Quote
