Havok248 Posted August 23, 2009 Report Posted August 23, 2009 Okay, i fixed my idle screw so the whole tors removal works as it should now, i have the correct size mains (or close enough) i have good spark on both plugs so neither fouled out and both are getting spark... It starts no problem but i notice exhaust barely comes out of the left pipe when i hit the throttle there is alot of white smoke and if i nail it for a couple of seconds the pipe shits fuel everywhere.. i cant figure out why im not getting anything on the left cylinder. Quote
Havok248 Posted August 23, 2009 Author Report Posted August 23, 2009 anybody? i really want to get this thing running. Quote
tundish2800 Posted August 23, 2009 Report Posted August 23, 2009 If you have a spare coil try that mine was cutting out doing the same thing at high rpm. Quote
Havok248 Posted August 23, 2009 Author Report Posted August 23, 2009 If you have a spare coil try that mine was cutting out doing the same thing at high rpm. no my cylinder wont fire at all.. Quote
fastrthnu Posted August 23, 2009 Report Posted August 23, 2009 no my cylinder wont fire at all.. maybe a blown gasket/o ring is letting water in that cylinder. Quote
Larry's Shee Posted August 23, 2009 Report Posted August 23, 2009 My son's shee had simular problem. Had spark both sides, but not fire. Cleaned poles on stator,inside of flwheel, lugs for pickup, and pickup coil. Gapped at 18tho, problem solved. Hope this helps. Quote
Havok248 Posted August 24, 2009 Author Report Posted August 24, 2009 My son's shee had simular problem. Had spark both sides, but not fire. Cleaned poles on stator,inside of flwheel, lugs for pickup, and pickup coil. Gapped at 18tho, problem solved. Hope this helps. if that were the case then wouldnt swapping the wires move the problem to the other side? im going to try tomorrow, hopefully if it doesnt work i can rule out a spark issue Quote
