x_doug_x Posted August 20, 2009 Report Posted August 20, 2009 reed cages for a fully mod'd stock cylinder stock crank motor. the inlet is too small on the boysens i have. also need intake boots for 34mm carbs. could also use some like new filters for 34mm carbs. i have to trade or sell stock reed cages with aftermarket carbon fiber reeds, 2 sets actually one has brand new boysen superstock reeds never ran. with allen screws instead of phillips. the other is carbon fiber reeds on stock cages i have no idea of brand. also have a set of aftermarket boysen reed cages for a stock carb motor. have stock chromed swingarm it did sit for a while and has some "Surface Rust" but i put a hand wire brush on it and got it off, there was only a little bit in some of the joints, but if you look at it hard you can see orange where the spots were however i think this will clean off. stock handlebars.. stock carbs with a box of new jets i bought off ebay that range "i think" from 27 to 30 somthing pilots and from 190 to almost 400 mains. if intrested in any of this stuff post and i'll get pics, i really don't need any of it. Quote
Banshee 410 Mayhem Posted August 20, 2009 Report Posted August 20, 2009 Bump- How much for the stock carbs? and jets? Quote
x_doug_x Posted August 20, 2009 Author Report Posted August 20, 2009 (edited) Bump- How much for the stock carbs? and jets? 125 for carbs, tors, cable, and the complete jet kit plus shipping. idk how much that will be if you are still intrested i'll get a picture of all for you. the cable worked for me but it prob. needs replaces, where the 2 cables go into one the plastic is cracked. i took it out with the tors hooked up and carbs synced and it ran fine for a little while then it started not revving so i unplugged the tors box and it ran fine after that, i dunno if the tors are messed up or if the tors box is bad. Edited August 20, 2009 by x_doug_x Quote
x_doug_x Posted August 20, 2009 Author Report Posted August 20, 2009 (edited) need a good clutch basket. Edited August 20, 2009 by x_doug_x Quote
