Yes thats a 2.50mm over or .100 over.
Thats 375cc
Wiseco has them here, last one at the bottom.
http://www.wiseco.com/ProductSearch.aspx
Edit* That is cutting it real close IMO. The cyl walls are real thin with a .100 bore. Doable and run killer, yes. Ideal size to run, no.
Giver a go. Or find some stock good shape low bore cyls on here for dirt cheep. Theres some all the time on here, think theres a pair or two right now for sale.
Have a look. :beer:
I ran a set .100 over for years with NO problems. But i did have it on alky and i used common sense.
does alky run cooler? mine will only be ran a few drags a year
If you have a ton into porting on your cylinders, you can go for broke by running the 66.50mm. Keep a close eye on things. (Open every 20 hrs). Problem with thin sleeves is any piston slap will break them and make change. They are also more subject to distortion when hot thus wearing out your pistons faster. If you are running stock or mild jugs, probably better to get different cylinders.
Brandon
