LegalizeFreedom Posted August 3, 2009 Report Posted August 3, 2009 What's going on? On iTouch so will keep short. I'm looking to cut my front fenders, what is the best tool for the job? Thank you. Quote
XxMeltIcexX Posted August 3, 2009 Report Posted August 3, 2009 What's going on? On iTouch so will keep short. I'm looking to cut my front fenders, what is the best tool for the job? Thank you. I used a sharpie and a sawzall Quote
LegalizeFreedom Posted August 3, 2009 Author Report Posted August 3, 2009 I used a sharpie and a sawzall Did your lines come out clean or did you have to sand? I ask because it sounds a bit much. Thanks. Quote
XxMeltIcexX Posted August 3, 2009 Report Posted August 3, 2009 Did your lines come out clean or did you have to sand? I ask because it sounds a bit much. Thanks. You have to use sand paper when cutting with anything, its not hard by any means. Quote
okbeast Posted August 3, 2009 Report Posted August 3, 2009 Sawzall or jigsaw works well too. Sandpaper, file, and a small torch does wonders. Quote
XxMeltIcexX Posted August 3, 2009 Report Posted August 3, 2009 LMAO I did say sawzall!!! I meant jigsaw... sawzall would be fuckin hard man!!!! my bad. Quote
banshee#44 Posted August 3, 2009 Report Posted August 3, 2009 yea i was wondering about the sawzaw thing lol . i personally used a jigsaw and did a little sanding after. Quote
tidos76 Posted August 3, 2009 Report Posted August 3, 2009 sawsal..... :yelrotflmao: i just used a box blade and sand paper. Quote
madjimmax Posted August 3, 2009 Report Posted August 3, 2009 I used a pair of orange handled aviation snips. The ones with 2 to 2 1/2" blades tape of with masking tape first so you make lines without writing on plastics. Take a little at a time until you get were you want to be and as long as you cut straight no sanding required. Quote
okbeast Posted August 3, 2009 Report Posted August 3, 2009 Gotta do whatcha gotta do if you don't have a jig-saw around. With the right blade I think anything would work fine lol. Quote
Hulio-mv Posted August 3, 2009 Report Posted August 3, 2009 I used a heat gun to soften it up a little and then used a carpet knife Quote
springer Posted August 3, 2009 Report Posted August 3, 2009 I used a heat gun to soften it up a little and then used a carpet knife ^^^good idea. i just used masking tape and a box knife. i suppose you could heat the knife up to make it a lil easier too. Quote
vulvafan537240 Posted August 4, 2009 Report Posted August 4, 2009 rambo knife and spit :biggrin: Quote
quaddad817 Posted September 21, 2009 Report Posted September 21, 2009 mask off your lines and cut them with a jigsaw- fine blade! overshoot the line by a 1/8'' when its all cut use a d,a or orbital sander to clean up the edges! if you start with 80 grit and go to 220, 320, 400 when you finnaly get to the tape line block sand with 600! and it will look factory. HAVE FUN B PATIENT! Quote
fastrthnu Posted September 21, 2009 Report Posted September 21, 2009 use a hedge trimmer or a skill saw, or ox-ace torch. I think theres a 311 page manual at the barnes and noble on cutting plastic,... I recommend that read right there before tackling such a feat. Quote
