Hey guys, I just got a banshee and can get an aftermarket AMR rev box locally and was wondering if it is worth the money?
It says it changes timing, but i think you guys would recommend to change timing mechanically. right or wrong?
it also says it lifts the rev limiter... Do banshees have a rev limiter? At WOT i dont hear the motor limiting any gear, i just shift into a higher gear when i feel it stops pulling..
thanks in advance!
thanks in advance!
I personally like timing plates, stock CDIs work great.
and what about the rev limiter? So is this a mod that no one here does?
i've been reading around and have come up with some questions so if anyone can answer them it'd be appreciated-
- How do VF2 reeds compare to VF3?
- my main jets are 290s, why do i see people with huge motors/huge carbs running 155 jets?
-On a stock bore, non ported, pump gas motor - whats the most compression and timing you can run reliably?
- should i get a cool head or just have my stock head milled for proper psi/squish?
thanks everyone
I have never seen someone hit the rev limiter. I run a dyna cdi and I like it a lot more than the timing plate advance way of doing it. I dont know about the box your looking at.
they are pretty close to the same thing. the vf3 use a snap in system that eliminated the screws from the vf2. either one would be fine for you.
because keihin aftermarket carbs use a jet system that uses pilots like 45,48,50,52,55 etc and main jets like 155,158,160,162,165 etc.
170 psi is a pretty safe psi to run on any motor. itll give you more bottom end grunt without sacrificing too much rev on top. +4 timing is a good mod for just about any bike. you have to be sure to run the proper octane fuel for increased compression and timing.
go with a NOSS head. dave is a site sponsor and makes great products. his screen name here is dlnoss.
170 psi will result in what Tyler said, however, if your wanting to stick with pump gas I would stick closer to 150 psi. As Tyler said, you will need to adjust your octane to run higher compression and more timing.
SP
