creiss13 Posted August 3, 2009 Report Share Posted August 3, 2009 whats up everybody.. I just got my first banshee finally!!its a 01 bored to a 400cc dual fmf exhaust and dual air filters. Here's the thing. It wasnt running when I got it. I put in new plugs fresh gas cleaned both carbs twice! it starts up now on bout 1st or 2nd kick, idles to me kinda high, and as soon as you touch the throttle it boggs out and will die.. I can idle around my yard in every gear until I hit the throttle. I need help with this kinda lost when it come to having two of everything! Thanks!! Quote Link to comment Share on other sites More sharing options...
matt1 Posted August 3, 2009 Report Share Posted August 3, 2009 whats up everybody.. I just got my first banshee finally!!its a 01 bored to a 400cc dual fmf exhaust and dual air filters. Here's the thing. It wasnt running when I got it. I put in new plugs fresh gas cleaned both carbs twice! it starts up now on bout 1st or 2nd kick, idles to me kinda high, and as soon as you touch the throttle it boggs out and will die.. I can idle around my yard in every gear until I hit the throttle. I need help with this kinda lost when it come to having two of everything! Thanks!! Sounds like the parking brake switch. That will let it start but not rev up. Quote Link to comment Share on other sites More sharing options...
dragbanshee98 Posted August 3, 2009 Report Share Posted August 3, 2009 sounds like a jetting issue... do you know much about jetting a 2 stroke??? Quote Link to comment Share on other sites More sharing options...
creiss13 Posted August 3, 2009 Author Report Share Posted August 3, 2009 Sounds like the parking brake switch. That will let it start but not rev up. whats the best way to fix that? Cuz on the lever the parking brake lock doesnt have anything to lock too. just kinda hangs there. Quote Link to comment Share on other sites More sharing options...
creiss13 Posted August 3, 2009 Author Report Share Posted August 3, 2009 sounds like a jetting issue... do you know much about jetting a 2 stroke??? No carbs and jetting is my weak spot.... Quote Link to comment Share on other sites More sharing options...
alf44 Posted August 4, 2009 Report Share Posted August 4, 2009 Is the choke on? Quote Link to comment Share on other sites More sharing options...
slopoke Posted August 4, 2009 Report Share Posted August 4, 2009 how do you bore one to 400? I want to know Quote Link to comment Share on other sites More sharing options...
YELLOWBANSHEE06 Posted August 4, 2009 Report Share Posted August 4, 2009 (edited) I had a similar problem with mine and it ended up being the microswitch on the throttle lever was stuck in, not sure what the switch does but it will definantly stop the bike from revving and cut the motor out when you try to rev it. Guessing it is connected to the ignition somehow. good luck. :cool: Edited August 4, 2009 by YELLOWBANSHEE06 Quote Link to comment Share on other sites More sharing options...
creiss13 Posted August 4, 2009 Author Report Share Posted August 4, 2009 I had a similar problem with mine and it ended up being the microswitch on the throttle lever was stuck in, not sure what the switch does but it will definantly stop the bike from revving and cut the motor out when you try to rev it. Guessing it is connected to the ignition somehow. good luck. :cool: Well the choke was not on... and I will def. take a closer look at these switches tonite.. Thanks for the help so far! Quote Link to comment Share on other sites More sharing options...
alf44 Posted August 4, 2009 Report Share Posted August 4, 2009 reeds in good shape? no cracks or tears. Quote Link to comment Share on other sites More sharing options...
TwistedSheeRida Posted August 4, 2009 Report Share Posted August 4, 2009 sounds electrical like said. and it sounds like you have a 361cc banshee so dont be one of the dummys who tells everyone they have a 400cc banshee Quote Link to comment Share on other sites More sharing options...
creiss13 Posted August 5, 2009 Author Report Share Posted August 5, 2009 sounds electrical like said. and it sounds like you have a 361cc banshee so dont be one of the dummys who tells everyone they have a 400cc banshee UPDATE! So the problem was in my ebrake sensor! Had it running good, took it out to test ride bout 2 hrs later and no spark. It seems like one go around it will get spark the next time no spark, my guess is the on off switch? Or is it something else? Thanks Quote Link to comment Share on other sites More sharing options...
