Hey guys, hopefully someone can help me here. I have an 06 banshee which is pretty much stock except for pipes, jetted carbs and air filter. The problem i am having is back a year ago i blew a head gasket, i pulled down the motor and did a top end rebuild. After the first couple of rides the overflow kept spitting out coolant and the bike was back firing, so i pulled the head back off to check and found the head gasket leaking into the cylinders again. So i removed the cylinders and sent them with the head to the machine shop to have them both faced just in case of slight warpage. I also fitted a genuine head gasket instead of the wiseco one that came with the rebuild kit. The head was torqued down correctly and re-torqued after a couple of heat cycles, I even used hylomar on the gasket to try help it seal up. A few more rides later and same problem, pulled the head off yesterday and found both cylinders leaking in at the intake side of the combustion chamber. Im stumped at whats wrong and not sure what to do next other than purchase new cylinders and head and start again . Any help would be much appreciated, thanks in advance.
