333bbb333 Posted July 26, 2009 Report Share Posted July 26, 2009 Hey I dont know the Tech term for them, but the guides or stops that come on the stock reed cages, are they needed, I have only one cage that has them and I am replacing the reeds with an aftermarket set and want to know if I should take the one set off, or find one to replace the side thats missing them. And any feelings on the best reeds to get, all I have done to bike is a set of t-5's and new 28mm flat slide carbs and airbox removed. Quote Link to comment Share on other sites More sharing options...
Natemills8 Posted July 26, 2009 Report Share Posted July 26, 2009 Are you gonna trail ride or drag race? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted July 26, 2009 Report Share Posted July 26, 2009 If you are going to use stock reeds, then you should probably have the stops. If you are using Boyesen reeds, the instuctions say to remove the stock stops. I have had problems with Boyesen reeds breaking in ported cylinders, and the solution was to install the stock stops. Quote Link to comment Share on other sites More sharing options...
333bbb333 Posted July 27, 2009 Author Report Share Posted July 27, 2009 Are you gonna trail ride or drag race? I am mainly Trail and MX Quote Link to comment Share on other sites More sharing options...
Natemills8 Posted July 27, 2009 Report Share Posted July 27, 2009 I am mainly Trail and MX Then Keep them stopers on it you dont wanna be out on a trail a few miles from the truck or your house and a reed brake off if you wanna do anything open them up alittle bend then open some but not a whole lot Quote Link to comment Share on other sites More sharing options...
lokisbuddy Posted July 27, 2009 Report Share Posted July 27, 2009 Just curious are the stops the metal things that hold the reed down? I just installed boyesens and I put it together in this order. 1:plastic petal with two square holes cut in it 2:carbon reed 3: metal funny thing to hold it down (off stock cage) is that right? Quote Link to comment Share on other sites More sharing options...
itsaripper Posted July 29, 2009 Report Share Posted July 29, 2009 Yes they are the little metal things. You can take a die grinder and cut off some of the outer end, so you can bend them out more, to let the reeds open more. But it is better not to take them off, because they help the reed to rebound. They accualy help at hi rpm. Where does the Banshee run? At hi rpm's the reed will just slap the sides of the intake and sooner or later brake. Then how come the v-force don't use them? Because the v-force has more petal surface and all them opening up at hi rpm is not enough to need the back up. Also the angle of the petal, very steep, it only has to move a little to be open. Quote Link to comment Share on other sites More sharing options...
lokisbuddy Posted July 29, 2009 Report Share Posted July 29, 2009 mine look like this well shit I cant draw a pic lol it looks like a quarter pipe coming off the top of the reed. is that normal? Quote Link to comment Share on other sites More sharing options...
shanYE west Posted July 29, 2009 Report Share Posted July 29, 2009 It depends on what reeds you replace them with. If you install the stop with the boyesen dual stage reeds it really hurts the performance. The rev plate replaces the stops. Quote Link to comment Share on other sites More sharing options...
