Keep pumping like you do with brakes.
Just when the bleeder is closed pump it 5 times instead of one time...will take a bit anyways.
Also at the beginning if its bone dry fill the rez and open the bledder and stick a hose on the end into a cup(so there is no mess) and let gravity help fill the line...takes about an hour or more this way AND then bleed it like i said above..it really helps alot and then its much easier to get bled.
  • 1 year later...
sick, ill give it a go
I just installed a Hydraulic Clutch on my Banshee last night. I haven't got to ride it with the new set up on there, but from what I've seen already I think I'm going to love it. I have a Drive Line Heavy Duty Clutch (with YZF 1000 Components) and a Barnett Dirt Digger Basket. I put the Drive line clutch in it because the Barnett didn't hold up worth a shit. I loved the HD Drive-Line Clutch but the pull was so stiff. So I tried a EZ Pull Lever by MSR, it felt more responsive but it didn't help the pull I ended up buying the Billetanium Hydraulic Clutch set up.
I bled mine with a syringe/needle. I installed it then I took the top line loose and used the need and syringe to fill it. After it was full I hooked it up and started pumping it and bled it out just like you would the brakes. I can't wait to get out in the woods and try it out.
Another thing to try is to fill it from the master cylinder up. Get a sringe and a pice of hose. Put it on the master cylinder opean the bleed valve and force the fuid up in to the resivour. Air tries to go up so if you fill from the bottom up it will help it along.
I just got mine Hydraulic Clutch on, and man is it nice. It might be one of the best mods I've done to my Banshee so far. I'm running a Drive-Line Heavy Duty Clutch and a Barnett Dirt Digger Basket. The clutch has held everything I've put to it and its great, the only down side to the Drive-Line HD Clutch was the pull. It was pretty stiff, and with me running 15/42 gearing in the woods it was hell on my hand. The Hydraulic Clutch made a huge difference.
I did have a little trouble bleeding it, I ended up buying a Bleeder and Pump from Auto Zone and that took care of the problem.
does any one else own one? i do but can seem to get it bled... any ideas why?
There a bitch to bleed. Keep at it. Once your done you'll love it.
