Natemills8 Posted July 23, 2009 Report Posted July 23, 2009 (edited) What size Pilot jet should I be useing my bike is Stock Bore With Superstock Piston with a full drag port 34mm PWK Air strikers on alky with GGR Drag PipeSB. They are 35s right now I just need to know if I should go bigger or smaller or lever them alone Edited July 23, 2009 by Natemills8 Quote
J-Madd Posted July 23, 2009 Report Posted July 23, 2009 How does it run? Does it start easily (with choke)? Sounds small, but if it ain't broke....... Quote
Natemills8 Posted July 24, 2009 Author Report Posted July 24, 2009 Its a stock stroke stock bore ride ported motor my buddys 4mil cub with 35.5s on it has a 48 jet in it he said I might need to go smaller but it will start up with out the choke the second or third kick Quote
Sammy Posted July 24, 2009 Report Posted July 24, 2009 If it starts easily cold without the choke, then your pilot is to rich. Go down a size on the pilot, retune your mixture screws and try that. Quote
Natemills8 Posted July 24, 2009 Author Report Posted July 24, 2009 So go down a size is it a 34 or a 30? I can turn the powerjets off & the air screws out 3 turns & it will run & not run out of fuel goin down the track Quote
dajogejr Posted July 24, 2009 Report Posted July 24, 2009 Your pilots have nothing to do with the bike's throttle being wide open. Your air screws and pilots control off idle to just under 1/4 throttle. If your bike doesn't have triple exhaust ports, good chance you don't need a powerjet, even on alky. Air Strikers jet a little different than conventional PWKs. Quote
Natemills8 Posted July 25, 2009 Author Report Posted July 25, 2009 (edited) How can you tell the differnce between a airstriker and a regular PWK.. it dont have any problem with the throttle I just need to know what size piolet jet I need its a 35 right now me and my buddy think I should put a 30 in it and see how it does its to rich right now Im guessing if I can start it on fog gas the 2nd kick Edited July 25, 2009 by Natemills8 Quote
blueshee03 Posted July 27, 2009 Report Posted July 27, 2009 How can you tell the differnce between a airstriker and a regular PWK.. it dont have any problem with the throttle I just need to know what size piolet jet I need its a 35 right now me and my buddy think I should put a 30 in it and see how it does its to rich right now Im guessing if I can start it on fog gas the 2nd kick if they are 34mm carbs they are not air strykers.if they are air strykers then they are either 35 or 38mm and will have 2 fins in they inlet side .if you have 34mm keihins they are most likely pj's.the main difference between pj and pwk keihins is that you set the idle on pj's by turning the choke knob and pwk's have idle screws.as for the the pilots as far as i know the smallest pilot jets they make for them is 35's. Quote
Natemills8 Posted July 27, 2009 Author Report Posted July 27, 2009 if they are 34mm carbs they are not air strykers.if they are air strykers then they are either 35 or 38mm and will have 2 fins in they inlet side .if you have 34mm keihins they are most likely pj's.the main difference between pj and pwk keihins is that you set the idle on pj's by turning the choke knob and pwk's have idle screws.as for the the pilots as far as i know the smallest pilot jets they make for them is 35's. Well there not pjs it says PWK on the side of them so Im guessing they are 35s then its got s d shaped slide ill find a picture so you can tell me what they are Quote
Natemills8 Posted July 27, 2009 Author Report Posted July 27, 2009 This is the back of the slide: Quote
quadgod211 Posted July 27, 2009 Report Posted July 27, 2009 i would just leave it be unless you are having problems at the track coming off the line to rich or busting up first 100ft.... or when you rev it it takes a second to pick up......other then that i wouldnt let it get to me... what track do you race at ky???? matt Quote
Natemills8 Posted July 28, 2009 Author Report Posted July 28, 2009 (edited) Outback Its like its hookin to hard off the line for the motor to pull but when it does wanna go it gets out about 10 feet & runs out of gas so times. I think it was in the wiring my buddy messed with it alittle & the left side richend up Edited July 28, 2009 by Natemills8 Quote
