NunavutBanshee350 Posted July 22, 2009 Report Posted July 22, 2009 Hey Guys having some trouble with my carbs. when I go slow with my shee it doesnt run too well but once I go fast it runs awesome need to know what should I do have some 45 pilot jets should I change them? I've got a Gnarly pipe K&N Powerlid Vforce reeds. What do u think I should do? The idleing runs pretty shitty times it tens to shut off some times Having hard time with it, Hard to tune.wondering if I should get some Mikuni Flat Slides. Quote
LiftdT4R Posted July 22, 2009 Report Posted July 22, 2009 Hey Guys having some trouble with my carbs. when I go slow with my shee it doesnt run too well but once I go fast it runs awesome need to know what should I do have some 45 pilot jets should I change them? I've got a Gnarly pipe K&N Powerlid Vforce reeds. What do u think I should do? The idleing runs pretty shitty times it tens to shut off some times Having hard time with it, Hard to tune.wondering if I should get some Mikuni Flat Slides. I have the jetting specs for your setup written down somewhere. I have the same setup, and I used to run the 28s, they are good carbs, the Mikuni 30s wont be any easier to tune. Ill try and dig out my old jetting specs tomorrow. Quote
Fullthrottle02 Posted July 22, 2009 Report Posted July 22, 2009 what pilots are in it now? I would think you should be around 48's Quote
NunavutBanshee350 Posted July 22, 2009 Author Report Posted July 22, 2009 what pilots are in it now? I would think you should be around 48's 45 Pilot jets are on right now. Quote
Fullthrottle02 Posted July 22, 2009 Report Posted July 22, 2009 I have all the bolt on's you have + a trail port and I'm at 50 pilots. Seems like it just might be staving at idle. Quote
DallasGDub Posted July 22, 2009 Report Posted July 22, 2009 Do you know what needles you have and what notch they are sitting? Quote
LiftdT4R Posted July 22, 2009 Report Posted July 22, 2009 I ran a 48 Pilot and 140 mains. As far as the correct needle, if you call up Carb Parts Warehouse and buy stuff from them they should help you out with the right needles. Quote
T_Shee Posted July 23, 2009 Report Posted July 23, 2009 yah id bump your pilots and see what happens. i currently have 50 pilots in my pwk 28s and when i went down to 45's it idled and revved like crap. seemed like it was fouling plugs and had a really bad air leak. but when i put the 50's back in it was perfect again. get some 48 or 50 and see what happens. has it run fine before with this same carb setup? Quote
