924dr Posted July 20, 2009 Report Posted July 20, 2009 im located in cincinnati ohio i have a few things that i am wanting to get rid of so i can start my new build here is the list stock crank still in the shee $ 130 + the ride .050 stock cylinders they will need to be bored the ring dug into the cyl. wall $ make offer .080 stock cylinders $ 100 + ride front and rear (red) plastic the rear has a slight crack in it $ make offer 2 into 1 carb kit 35mm pwk uni filter throttle cable $ 185 +ride +8 stock style swinger comes with extended s.s. brake line $ make offer i dont have pics of the 2 into 1 kit or the .050 over cylinders but i will get them once my wife gets home justin Quote
parttimer Posted July 21, 2009 Report Posted July 21, 2009 im located in cincinnati ohio i have a few things that i am wanting to get rid of so i can start my new build here is the list stock crank still in the shee $ 130 + the ride .050 stock cylinders they will need to be bored the ring dug into the cyl. wall $ make offer .080 stock cylinders $ 100 + ride front and rear (red) plastic the rear has a slight crack in it $ make offer 2 into 1 carb kit 35mm pwk uni filter throttle cable $ 185 +ride +8 stock style swinger comes with extended s.s. brake line $ make offer i dont have pics of the 2 into 1 kit or the .050 over cylinders but i will get them once my wife gets home justin are you selling the pro design cool head in the pic? Thanks, Quote
chevybanshee91 Posted July 22, 2009 Report Posted July 22, 2009 .80 cylinders do they come with pistons and do they need to be bored or honed? Quote
924dr Posted July 22, 2009 Author Report Posted July 22, 2009 what's up with those rear plastics sorry i thought i pm'd you back i will pm you now Quote
924dr Posted July 22, 2009 Author Report Posted July 22, 2009 here is a pic of the 2 into 1 kit here is the .050 over cylinders the extended studs are not included this is a pic of the damaged one and its not bad at all prolly could do a lite hone and rock it i will get more of these cylinders here is the .080 set of jugs Quote
