blu01shee
About blu01shee
  • Birthday 05/26/1983
Contact Methods
  • Website URL
    http://
  • ICQ
  • Yahoo
    jones2483
    Kentucky
blu01shee's Achievements
  1. ECshee has dibs on the seat. I will get pics of the rest in the morning
  2. Have 2 sets of reeds Stock cages with Vitos Carbon fiber almost brand new Aftermarket ones are like Aluminum cages with decent reeds Have pic ture that i can email you of them both of them. Iwould like to know what kind the aftermarket ones are
  3. The caliper is gone and the rotor was warped pretty bad so i trashed it. Sorry
  4. 98 frame and 96 motor Banshee complete part out. Ran great started first kick then crank went out. So now its being parted out. Will cut deals on multiple items. A arm frame with no title $150 SOLDFresh bore .30 cylinders and wiesco pistons $400 SOLD tranny $100 stator $50 adjustable timing plate $30 flywheel $75 a-arms $150 axle $100 hubs $60 FMF Fatty Gold Series and Power core silencers $150 handlebars $20 carbs with throttle cable $55 intakes $30 airbox and new filter$40 Reed spacers $15 New clutch plates and clutch basket $100 swingarm $50 plastics race cut $70 for everything will sell peice by peice seat $20 radiator $20 wiring harness $50 CDI, Voltage reg. coil $75 brake lines an rotors front $45 front calipers $45 Front shocks $25 Pegs $25 Cases top and bottom $100 Stock jugs with one broke sleeve $50 After Market reed cages with good reeds $50 Aluminum front wheels $40 Aluminum 9" rear wheels $50 10" rear wheels $50 Will sell everything left for $700 Thanks call Brad 502-257-3355 if no awnser leave mesg.
  5. Bump for a nice Banshee CHEAP
  6. Louisville. Cant load the pics but can email them its not the one in my sig
  7. Bad 04 Banshee For Trade Needs nothing. Very fast. Starts first kick everytime and idles great. Good reliable 4 wheeler. Spring is not that far away $2200 firm 80 over with Wiesco's (both cylinders are at 165 psi) New stock Crank when fresh bore was done 20 hrs.ago Milled stock head Boost bottle New vitos carbon fiber reeds Stock carbs with 320 mains K&N pods Billet reed spacers Billet thumb throttle Renthal bars Toomey T5 ehxaust AC aluminum nerfs with heel gaurds Polished aluminum side cover Blingstar aluminum front bumper Douglas wheels Good Holeshot rears Good Front tires Good Set of Dune tires on wheels Not the pics in my sig
  8. Thanx for your help. Thats the only way to be able to run my air box. But the KN pods are shot outer wears have burn holes.
  9. Just got another banshee yesterday. Went to put my airbox on it to replace the k&n pods and the box of my parts bike has been cut back on the carb side to fit the reed spacers and the boots are to short. My questions are the spacers helpful or what do they actually do.
  10. I love my fast trekker tire they hook up better than holeshots and razrs and they are 6ply plus i got both of them plus shipping for $70.
  11. Thanks for your help and will make sure there is movement in the rad.
  12. All of my mods are in my sig. Just put it back together last night and was running through the heat cycles fine then all the sudden it starts steaming and spuing coolant out the over flow hose. It did this to me about a two weeks ago and lost all compresion so i tore it down and found a ring embedded in the head and blown head gasket so i sent the cylinders off to HJR (awsome job) and before i put back together took off the water pump cover to check and make sure it was functioning right and it was but when i looked at the back of the water pump cover you could see where the impeller had been rubbing it alot but put it back on. Checked all of my coolant hoses and they were fine. My radiator has no corrotion or build up in it. Bought a billet impeller, gear, washer, circlip that will be here on thursday but would like to know what else i need to check. Not sure why its doing this but any help or advise would be helpful and appreciated.
  13. are you goin to sell the shirts and some stickers as a package deal?
  14. PM sent for the crank
  15. Good set just bought t5s and need to sell these. They are are not the best looking but work great. Just repacked them. Sorry no pics tonight but will post some pics tomorrow. $125 shipped
