help needed
for the past two rides at mid throttle before the powerband the bike seems like its chocking about to die and it has killer top and bottem end , but the confusing part it doesnt happen all the time and sometimes it chokes really bad kinda like when you hit the killswitch and still try to rev it kinda just bogs out , and before last ride i started it to warm it up and i barly idled and couldnt even rev . so i did a minor carb clean and it got back to were it was on the other ride just choking on mid , now ive played with jetting so i know its not that ive had the same jetting for almost 2 years and nothing has been wrong before , i did a compression test they are both putting out 50-55psi with 30thous shaved head , any info would be GREAT i got a sand dune trip coming up in a month and a bit , need to get her back to 100%...thanx
I may of did the compression test wrong I just screwed it in and kicked it over once. I was just told I should have the throttle wide open and kick it a few times. So ill try that tomorrow and post updated numbers if they are different
50 to 55 seems very low. I think stock it should be 110
need some help.
got my new fmf pipes and k&n air filter just added
messing around with the jets got the main at 270 currently
air screw 1.5 turns
im 2600ft abv sea lvl so got the needle on third groove
my problem is machine will not keep a constant idle just dies out after letting off throttle
and backfireing
any solutions to my problem would be a great help.
