bansheecaptain Posted July 15, 2009 Report Posted July 15, 2009 for the past two rides at mid throttle before the powerband the bike seems like its chocking about to die and it has killer top and bottem end , but the confusing part it doesnt happen all the time and sometimes it chokes really bad kinda like when you hit the killswitch and still try to rev it kinda just bogs out , and before last ride i started it to warm it up and i barly idled and couldnt even rev . so i did a minor carb clean and it got back to were it was on the other ride just choking on mid , now ive played with jetting so i know its not that ive had the same jetting for almost 2 years and nothing has been wrong before , i did a compression test they are both putting out 50-55psi with 30thous shaved head , any info would be GREAT i got a sand dune trip coming up in a month and a bit , need to get her back to 100%...thanx Quote
bansheecaptain Posted July 15, 2009 Author Report Posted July 15, 2009 I may of did the compression test wrong I just screwed it in and kicked it over once. I was just told I should have the throttle wide open and kick it a few times. So ill try that tomorrow and post updated numbers if they are different Quote
yfz350rider Posted July 15, 2009 Report Posted July 15, 2009 I may of did the compression test wrong I just screwed it in and kicked it over once. I was just told I should have the throttle wide open and kick it a few times. So ill try that tomorrow and post updated numbers if they are different 50 to 55 seems very low. I think stock it should be 110 Quote
bansheecaptain Posted July 16, 2009 Author Report Posted July 16, 2009 both cyclinders are hitting 140psi , so im clueless besieds seeing what my reeds look like , any info if someone has had the same problem would be nice Quote
firebanshee Posted July 16, 2009 Report Posted July 16, 2009 Maybe you should do a major carb clean, it doesn't take much to plug a jet or a passage in a carb. :cool: Quote
bansheecaptain Posted July 16, 2009 Author Report Posted July 16, 2009 ya thats my next thing , my reeds are ok so my guess is thats the one thing left Quote
Badapwned Posted July 22, 2009 Report Posted July 22, 2009 ya thats my next thing , my reeds are ok so my guess is thats the one thing left Ever figure it out? Quote
rocknrolla Posted July 25, 2009 Report Posted July 25, 2009 need some help. got my new fmf pipes and k&n air filter just added messing around with the jets got the main at 270 currently air screw 1.5 turns im 2600ft abv sea lvl so got the needle on third groove my problem is machine will not keep a constant idle just dies out after letting off throttle and backfireing any solutions to my problem would be a great help. Quote
bansheecaptain Posted July 25, 2009 Author Report Posted July 25, 2009 ya i think i fixed it , it reved pretty smooth havent took it for a ride i got evacuated from my house because of a forrest fire. Quote
Badapwned Posted July 25, 2009 Report Posted July 25, 2009 ya i think i fixed it , it reved pretty smooth havent took it for a ride i got evacuated from my house because of a forrest fire. What was the fix? Quote
bansheecaptain Posted July 26, 2009 Author Report Posted July 26, 2009 major carb clean and had to turn over one of the pedels on my reeds Quote
