tt_bansheerida Posted July 11, 2009 Report Share Posted July 11, 2009 hey guys i went to install my old dyna box fs well the bike runs but once i give it some throttle the bike starts cutting out i belive its the parking brake wire i dont have it grounded out? what colour is the parking brake wire coming out of the dyna box and can i ground it back to the dyna box? i put my stock cdi box back on and it runs perfect but my porting is mde for the power curve in the dyna box so i need to put it back on Quote Link to comment Share on other sites More sharing options...
tt_bansheerida Posted July 12, 2009 Author Report Share Posted July 12, 2009 bump! Quote Link to comment Share on other sites More sharing options...
XxMeltIcexX Posted July 12, 2009 Report Share Posted July 12, 2009 Green/Yellow or Purple/Black depending on your year CDI.You dont need that wire, cut it off and keep it off of any ground. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted July 14, 2009 Report Share Posted July 14, 2009 Im pretty sure the park brake wire actually has to be grounded. Thats what I recollect. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted July 14, 2009 Report Share Posted July 14, 2009 Im pretty sure the park brake wire actually has to be grounded. Thats what I recollect. You can also program your parking brake rev limit to 12,000. rpms. Quote Link to comment Share on other sites More sharing options...
tt_bansheerida Posted July 17, 2009 Author Report Share Posted July 17, 2009 it turns out its the purple & white wire coming out of the cdi box i havent installed it yet but i will shortly i would just need to ground this wire out right? Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted July 17, 2009 Report Share Posted July 17, 2009 Yes. Quote Link to comment Share on other sites More sharing options...
brave&crazy racing Posted March 16, 2010 Report Share Posted March 16, 2010 Yes. if this is a banshee cdi do not ground p brake wire. leave it open. i will put money on it. if you put that wire to a ground it will trigger the p brake rev limiter. the rev limiter is set at 2600 stock.. it could be a bad cdi box i just sent one back that went bad.. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted March 16, 2010 Report Share Posted March 16, 2010 The partk brake rev limiter is limiting when the wire is grounded, when the park brake is set the switch there closes and connects the wire from the CDI box to the ground wire in the harness. If you want to do away with the limiter, just cut the wire out of the bike harness at the CDI plug and you will be good to go. With the wire cut out of the bike harness and still in the box side of the plug, it keeps it from becoming grounded. This is how my wife's 97 is set up and it gives us no problems. I know in 97 when this feature first appeared the wire was green/yellow, I don't know about later years. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted March 16, 2010 Report Share Posted March 16, 2010 there is also a stutter function on it. can't remember what wire it uses, but here is what i put down in my notes, lol 4:22 PM 1/21/2010 dyna f/s wires: brown-rpm activated switch. is 12v (-)500ma max for power jets blue- rom activated switch. is 12v (-)500ma max for power valves purple/white-rev limiter when grounded-2600rpm stock GREEN-? TACH? 12V PULSED Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted March 17, 2010 Report Share Posted March 17, 2010 I did not hookup any of that mess with my Dyna. I only plugged in the two large plugs for the stator and the blue wire for the recitifier. All the other crap I tied up with a zip tie. I never had any issues. Do you have all your tors crap removed? Quote Link to comment Share on other sites More sharing options...
