gohstmofo6996 Posted July 11, 2009 Report Share Posted July 11, 2009 (edited) Hey whats going on guys, im new at all this Banshee stuff. well my question is do i have a leak? ive had a kx 250 in the past and loved it but im just a quad 2 stroke guy so i picked up a 2002 shee. it runs like a raped ape, but when it gets really hot, or after long running time it seems that my coolant drips on my right exhaust pipe (Header if you will). it doesnt always do this only after a longer run and it gets hotter than just put putting. i just dont understand. and when its not running it doesnt leak... thanks. Edited July 11, 2009 by gohstmofo6996 Quote Link to comment Share on other sites More sharing options...
sheefreak Posted July 11, 2009 Report Share Posted July 11, 2009 It is getting hot enough to spit some coolant. It should be coming from the overflow. Could be caused by many things. Low coolant, bad impeller, lean jetting. What do your plugs look like? Still stock impeller? Quote Link to comment Share on other sites More sharing options...
firebanshee Posted July 11, 2009 Report Share Posted July 11, 2009 I have had the same thing happen to me on a couple of my bikes and i found that if you take off the radiator cover and put foam around the outside edge of the radiator (i use the foam tape with a sticky edge) then when you put your cover back on it fills in the gap between the radiator and the cover and forces the air to go through the radiator and not around it. Air will take the path of least resistance, this has worked well for me. :cool: Quote Link to comment Share on other sites More sharing options...
gohstmofo6996 Posted July 11, 2009 Author Report Share Posted July 11, 2009 hey thanks guys, and yes everything is stock. besides a bumper lol Quote Link to comment Share on other sites More sharing options...
