zach45 Posted July 9, 2009 Report Posted July 9, 2009 (edited) what parts will i need as far as barrings and seals... any other little things i should start to order? i just bought a whole motor and i plan to strip it to the balls, powder coat it etc and build a 4mm stock jugs trail bike.. most likey a HJR 4mill port job... and i want to keep the motr thats in my bike now together as posable... i might use the clutch and will defiantly use the flywheel and coil and my noss head when i buy my crank should i pay the extra money for a long rod? what is the difference? i play to use a new clutch pack maybe from FAST or RJATV/FLOTECK i want to have a lockup cover just for the looks but should i use the lock up clutch also? any other advice.. this is going to be my first motor build so far my parts list is 4mm crank pistons stroker domes lower end barrings lower end seals complete gasket set yamahabond Edited July 9, 2009 by zach45 Quote
GrMeyer Posted July 9, 2009 Report Posted July 9, 2009 #1 is the claimers manual #2 take your time #3 clean work place #4 I use a old coffee can to put all my nuts and bolts into #5 Money #6 Good TQ wrench #7 Micrometer #8 Timing plate #9 more from everyone else Quote
zach45 Posted July 9, 2009 Author Report Posted July 9, 2009 anyone i wanna start ordering parts... thanks Quote
BellicoseBanshee Posted July 10, 2009 Report Posted July 10, 2009 clutch nut lock washer cooling tube o-ring shift adjust bolt lock washer 32mm socket 24mm socket Quote
zach45 Posted July 10, 2009 Author Report Posted July 10, 2009 i assume those are for clutch basket? i have 24 ill go pick the other one up tomorrow Quote
BellicoseBanshee Posted July 10, 2009 Report Posted July 10, 2009 i assume those are for clutch basket? i have 24 ill go pick the other one up tomorrow Yes, the 32mm is for the clutch nut and sprocket nut. The 24mm is for the crank nut and the flywheel nut is 17mm. Quote
zach45 Posted July 10, 2009 Author Report Posted July 10, 2009 i have everything up to 28 i think with my craftsman kit... thanks... Quote
zach45 Posted July 10, 2009 Author Report Posted July 10, 2009 WOW how fucking easy was it to tear it down.. lol now if i can put it together ... Quote
