what parts will i need as far as barrings and seals...
any other little things i should start to order?
i just bought a whole motor and i plan to strip it to the balls, powder coat it etc and build a 4mm stock jugs trail bike..
most likey a HJR 4mill port job... and i want to keep the motr thats in my bike now together as posable... i might use the clutch and will defiantly use the flywheel and coil and my noss head
when i buy my crank should i pay the extra money for a long rod? what is the difference?
i play to use a new clutch pack maybe from FAST or RJATV/FLOTECK
i want to have a lockup cover just for the looks but should i use the lock up clutch also?
any other advice.. this is going to be my first motor build
so far my parts list is
4mm crank
pistons
stroker domes
lower end barrings
lower end seals
complete gasket set
yamahabond
Edited by zach45
#1 is the claimers manual
#2 take your time
#3 clean work place
#4 I use a old coffee can to put all my nuts and bolts into
#5 Money
#6 Good TQ wrench
#7 Micrometer
#8 Timing plate
#9 more from everyone else
