BANSH-alena-jol-EE Posted July 6, 2009 Report Posted July 6, 2009 hello, just took off the top end, i think there is coolant in my crankcase, i can see it underneath the crank...is that right? or did i fuck something up? when i took the cylinders off i think that some coolant did leak out from underneath the cylinders...i did try to drain the coolant though, perhaps i didnt drain it all out ? Quote
jbooker82 Posted July 6, 2009 Report Posted July 6, 2009 Did you pull the coolant drain bolts out of the side of the cylinders? Those are there so you can drain the cylinders before you tear it down. If you didnt that is probably how it got down there. I would just blow it out with an air compressor. josh Quote
