Which is best to use Super Light Tires With 12 Extreme Paddle Haulers or Super Light Tires with 14 Extreme Paddle Haulers for a
10 MIL?
10mil what? and where do you race/ride?
Yeah man, we're going to need a lot more info about your set-up. Ofcourse 14 haulers will be in the ball park, but we need to know things like, who ported it. Where are you going to be riding mostly? Is this a track bike or a dune bike?
It's only for the dunes.
Here's the Ingred.
CW-10 10mm Billet Crank
> SUPERCUB-10-P 10mm x 72mm Polished Super Cub Package
> HSCG Hinson Straight Cut Gears
> BHDC Heavy Duty Clutch Pak
> SHIFT- PRO Shift Pro ~Easy Shift~ Kit
> CDA Clutch Disengagement Adjuster
> CASE-BK Chrome Case Bolts
> CN-8 Chrome Cylinder Nuts
> MAN-B-P Polished Billet Manifolds
> 016-155-2P 39 Polished PWK Keihin Carburetors
> PING-D Dual Billet Aluminum Pingel Valve
> DYNA-97 Dyna Fs Ignition
> NSC Polished Aluminum Neutral Switch Cover
> 115-6TB/0820 K&N
521cc 10mm package
no everride?any ways i would say with your set up and you riding the dunes on a stock chassy and a +10swing arm no more than 11 paddle haulers[not extremes]
