I recently rebuilt my carbs and was not sure where this part went. It is a small about 1/8 inch od brass tube that installs on the bottom side of carb between the main jet and discharge of carb. My question is which carb does this go on and what does it do? Would it cause a hard cold start if it was in incorrect carb?
Is ther supposed to be one on each carb or just on the left carb?
The choke tube connects both carbs horizontally inline with the chock nob. Go have a look if its there and in place.
Edited by savage420
This is a BRASS tube in front of main jet. It sticks into the main body of the carb and hangs down into the float bowl. If the carb is upside down like when doing a float level adjustment It would be located between main jet and the discharge of the carb. I don t remember which carb it came from and wondered what it was for.
Sorry i skim read that.
Anyways i don't run stock carbs anymore but here is a couple pics you point to what your talking about and we will help you.
If you need diff pics just ask.
http://i27.photobucket.com/albums/c164/sav...20/DSCF0219.jpg
Im sure its not the second pics but what the hell hey!
http://i27.photobucket.com/albums/c164/sav...20/DSCF0218.jpg
:beer:
im not positive but i think that is either for a vent or an overflow i havent had mine apart in a while but i think what that is i think they both need them and im sure it has somekind of vital function otherwise it wouldnt be in there
:beer:
The first pic shows the tube I'm talking about, Do you have a pic like that of the other carb. Just wondering if I am supposed to have one in both carbs. Thanks I really appreciate your help.
It go's in the left or choke side carb only.
Edited by jbones
