fastrthnu Posted June 21, 2009 Report Share Posted June 21, 2009 Im having a brain fart,.. is there any way for coolant to get into a cylinder by other means than a head leak? My right cyl is filling with coolant, and cutting it out, and seems right away after heating up maybe 1 min of runnimg, my overflow starts spraying. I have no overflow hose on my radiator. I figure if a pump seal went bad, it just end up in the oil. Quote Link to comment Share on other sites More sharing options...
2strokespirit Posted June 21, 2009 Report Share Posted June 21, 2009 Im having a brain fart,.. is there any way for coolant to get into a cylinder by other means than a head leak? My right cyl is filling with coolant, and cutting it out, and seems right away after heating up maybe 1 min of runnimg, my overflow starts spraying. I have no overflow hose on my radiator. I figure if a pump seal went bad, it just end up in the oil. On a banshee cylinder it can enter through the rubber plug on the base of the cylinder and through the base gasket. On a Rz jug there is no plugs, so only through the head.. Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted June 21, 2009 Author Report Share Posted June 21, 2009 On a banshee cylinder it can enter through the rubber plug on the base of the cylinder and through the base gasket. On a Rz jug there is no plugs, so only through the head.. thanks mang. Quote Link to comment Share on other sites More sharing options...
yamahaman244 Posted June 21, 2009 Report Share Posted June 21, 2009 thanks mang. Im having the same problem the right side so it can only be the head gasket or the head Quote Link to comment Share on other sites More sharing options...
