POORBOY350 Posted June 20, 2009 Report Posted June 20, 2009 i have 35mm pwks. keihen or however you spell it and im wanting to just try moving the needle clip up one notch because it is just a lil too much on the rich side. and i believe moving it up one will be good. but ive never been in these carbs tho i have done jet kits on alot of other bikes. thanks. Quote
wesw Posted June 20, 2009 Report Posted June 20, 2009 (edited) then open the bitchs up and move the clip. not rocket science. Edited June 20, 2009 by wesw Quote
00tbanshee Posted June 21, 2009 Report Posted June 21, 2009 if you move the clip up it will lean it out.wes, way to make him feel good!!!!.i never mess with moving the clip just keep it in the middle,if you need it leaner then get another needle Quote
wesw Posted June 21, 2009 Report Posted June 21, 2009 if you move the clip up it will lean it out.wes, way to make him feel good!!!!.i never mess with moving the clip just keep it in the middle,if you need it leaner then get another needle didnt try to make him feel good just saying its pretty easy to take top off carb, unscrew or bolt the cable holder and pull the needle and take pliers or needle nose and pull the clip and put it on the one you want. now to your statement about getting another needle why would he need to do that if its a rich needle he could run 2nd or first clip. instead of paying 12 bucks for a pair of needles to try to run in the middle. save him some money. Quote
POORBOY350 Posted June 21, 2009 Author Report Posted June 21, 2009 didnt try to make him feel good just saying its pretty easy to take top off carb, unscrew or bolt the cable holder and pull the needle and take pliers or needle nose and pull the clip and put it on the one you want. now to your statement about getting another needle why would he need to do that if its a rich needle he could run 2nd or first clip. instead of paying 12 bucks for a pair of needles to try to run in the middle. save him some money. i took the top off but didnt see how the needle came out, i know its not that hard so why dont you tell me after you take top of carb off hhow do you get needle out does it unscrew or what Quote
POORBOY350 Posted June 21, 2009 Author Report Posted June 21, 2009 then open the bitchs up and move the clip. not rocket science. well how do you get the needle out does the whole piece that holds the cable unscrew or what smart ass Quote
Blewbyu Posted June 21, 2009 Report Posted June 21, 2009 Yeah, I believe its an 8mm, unscrew the piece inside the slide that holds the cable. Be carefull though, they can be a bitch and break if they are in there real tight. Quote
POORBOY350 Posted June 21, 2009 Author Report Posted June 21, 2009 Yeah, I believe its an 8mm, unscrew the piece inside the slide that holds the cable. Be carefull though, they can be a bitch and break if they are in there real tight. thanks buddy i just figured that out lol. next question is how much diff would moving it up one knotch make? it was on second from the bottom so i moved it up one so now its in the middle but it was pretty rich and wass foulin plugs pretty fast Quote
wesw Posted June 21, 2009 Report Posted June 21, 2009 heres an idea your running a cub by your sig what is your pilot what is your needle lil letters on the side what is your main we then probably could tell you what each of those should be to get it running close. by the way depending on what needle but usually mid clip works well with a cub. Quote
POORBOY350 Posted June 21, 2009 Author Report Posted June 21, 2009 heres an idea your running a cub by your sig what is your pilot what is your needle lil letters on the side what is your main we then probably could tell you what each of those should be to get it running close. by the way depending on what needle but usually mid clip works well with a cub. I can get all that... i moved it to the middle it was 2nd from the bottom. it leaned it out a lil bit feels a lil better. but it dont feel like its pullin as hard but its cleaner running so thats better. which i rode it once with my new plugs and it could have done fouled em enough to effect how it runs. this bitch is so tempermental. Quote
POORBOY350 Posted June 21, 2009 Author Report Posted June 21, 2009 and i also know it is gonna take alot of time and money and races to get it setup where i want it at its best but i will get in there and see what the pilot main and needle are. thanks. Quote
