No Limit Powersports Posted June 18, 2009 Report Posted June 18, 2009 Ok guys here is the deal on this motor. This was a 04 model motor that a customer had me build and now wont pay me for. Here is the details on the motor. 4mm cub drag ported (new) modquad head 19cc custom cut domes (new) ARP head studs and caps Wiseco Pistons (new) Hotrods 4mm longrod crank welded and maxload (new) 1-5 ND Duneable Override (new) Direct Drive Lockup and 12 bolt die cast polished cover (new) New Clutches Clutch disengager (pancake bearing) (new) Billet one piece intakes 33-36mm (new) Vforce II reeds Ricky stator adjustable stator plate Used 36mm lectrons on alky This motor is setup to run on alky around 1000ft should make 180-190lbs of compression and has +7 degrees on the plate. This is a complete drop in motor everything you need to make it run except exhaust and filters, and have both of those in stock. This motor with 40mm lectrons and shearer pipes is capable of 105+ hp Not looking to part it out yet would just like to sell it as a whole so I can pay the bill off. The bill on this motor was $3932 before taxes inluding everything above and would be interested in giving someone some credit on a good complete bottom end as well. Andy M&M ATV Quote
No Limit Powersports Posted June 24, 2009 Author Report Posted June 24, 2009 someone needs a complete runner Quote
No Limit Powersports Posted July 28, 2009 Author Report Posted July 28, 2009 Ok guys this needs to go. No carbs $3300 Quote
