bansheenut24 Posted June 17, 2009 Report Posted June 17, 2009 Help!! Has anybody else had this problem? I keep losing the same one of these two plugs. They are where the shaft, that the shift forks ride on. The E clip on the inside doesn't come off and the shaft doesn't slide out, just the plug comes out and then leaks oil. Any ideas? Quote
Thewhite Posted June 17, 2009 Report Posted June 17, 2009 Help!! Has anybody else had this problem? I keep losing the same one of these two plugs. They are where the shaft, that the shift forks ride on. The E clip on the inside doesn't come off and the shaft doesn't slide out, just the plug comes out and then leaks oil. Any ideas? glue them with epoxy Quote
blowit Posted June 17, 2009 Report Posted June 17, 2009 Get a new plug and squash it slightly in a vise to expand the OD slightly so you increase the interference fit. Also a good idea to apply a small amount of RTV to the OD to help seal it. Should be a 5 min job. B Quote
Snopczynski Posted June 18, 2009 Report Posted June 18, 2009 Cascade sells them. You gotta glue them in. Quote
spurdy Posted June 18, 2009 Report Posted June 18, 2009 Cascade sells them. You gotta glue them in. Had the same issue. Yamabond and a slight ping on the outside to increase the interference fit as previously stated. SP Quote
bansheenut24 Posted June 18, 2009 Author Report Posted June 18, 2009 Thanks everyone for your ideas, I will put it back in and go ride!!! Quote
