Just wondering what a basic banshee water temp is.....Mine runs around 180 degrees.....should this be warm enough? I have a very large radiator....
Perfecto :thumbsup:
Yea that is what I shoot for on my banshee. Mine runs in the 160 range in the winter. and 190-210 in the hot summer. It just depends on how I am riding. Poking along in the trails with 4 strokes cause it to warm up a little. I shut it down around 220-225. My temps are measured right at the head outlet with a digital trail tech vapor.
Do you have a picture of the sensor installation ? The head water outlet pass between the two reed valve and you got enought space or you install it after the water pump ?
No it is installed on the other side of the head (front). Coolant is pumped from the bottom of the radiator, through the pump, up the hose inbetween the intakes, through the head, and then to the top of the radiator.
It is just one of those billit aluminum adaptors that has an electric probe installed. I use a trail tech vapor.
josh
