Steves banshee Posted June 4, 2009 Report Posted June 4, 2009 I just purchased a stock swing-arm from a seller on this board, its for a 01 shee will it fit my 87Shee? I would think they fit all years, but i could be wrong? Nothing wrong with mine, the guy i got my shee from painted it dull black and i want the powdercoat grey look again. Thanks :biggrin: Quote
cornfeedbanshee Posted June 4, 2009 Report Posted June 4, 2009 I just purchased a stock swing-arm from a seller on this board, its for a 01 shee will it fit my 87Shee? I would think they fit all years, but i could be wrong? Nothing wrong with mine, the guy i got my shee from painted it dull black and i want the powdercoat grey look again. Thanks :biggrin: SHOULD FIT. THE ONLY THING THAT CHANGED FROM THEN TO NOW IS THE A-ARMS Quote
xXBlessedWithDeathXx Posted June 4, 2009 Report Posted June 4, 2009 The carriers were different but same swingarm. Quote
BellicoseBanshee Posted June 4, 2009 Report Posted June 4, 2009 My buddy installed an '01ish swinger on his '88, and it was not the same. The bushings that are welded to the upper carrier mounts on the '88 are on the outside, where the bushings on the '01 are on the inside... You are going to need a newer carrier (at least one that matches the newer style arm). I will be curious to know if I am loosing my mind or not, but that is what I remember... Quote
Steves banshee Posted June 5, 2009 Author Report Posted June 5, 2009 Thankyou :biggrin: My buddy installed an '01ish swinger on his '88, and it was not the same. The bushings that are welded to the upper carrier mounts on the '88 are on the outside, where the bushings on the '01 are on the inside... You are going to need a newer carrier (at least one that matches the newer style arm). I will be curious to know if I am loosing my mind or not, but that is what I remember... Quote
xXBlessedWithDeathXx Posted June 5, 2009 Report Posted June 5, 2009 i had a 87 swingarm and a newer carrier. i never had any problems with mounting. so in return i dont think you'll have any problems with a new swingarm and a older carrier. Quote
