kingsley Posted June 3, 2009 Report Posted June 3, 2009 Im after a little help with jetting selection for my 04. Im running FMF fattys, stock carbs, K&N filter, 22cc coolhead, 66.5mm bore, 4mm stroker. 98octane 25:1 synthetic. Most of the running is on the dunes, close to sea level. Thanks in advance Quote
VegasJeff Posted June 3, 2009 Report Posted June 3, 2009 Im after a little help with jetting selection for my 04. Im running FMF fattys, stock carbs, K&N filter, 22cc coolhead, 66.5mm bore, 4mm stroker. 98octane 25:1 synthetic. Most of the running is on the dunes, close to sea level. Thanks in advance I ran the exact same setup as you,except not a 4mil.I had 280 main jet/stock pilot with the middle clip on yhe stock needle at an elavation of 2100ft.You could start there and do a few plug checks. Quote
odaen Posted June 3, 2009 Report Posted June 3, 2009 Im after a little help with jetting selection for my 04. Im running FMF fattys, stock carbs, K&N filter, 22cc coolhead, 66.5mm bore, 4mm stroker. 98octane 25:1 synthetic. Most of the running is on the dunes, close to sea level. Thanks in advance K&N filter with the lid on, off, or K&N pods? Lid on, I think I ran a 260 main with my T5's Lid off, probably 280'ish Pods, probably around 320'ish Quote
kingsley Posted June 4, 2009 Author Report Posted June 4, 2009 K&N filter with the lid on, off, or K&N pods? Lid on, I think I ran a 260 main with my T5's Lid off, probably 280'ish Pods, probably around 320'ish Running a K&N pod with a pre filter, lid on. Quote
