If you were to take a 4mm serval,run the 7mm crank, no base gasket and cut domes, Would that be what you would work with?
If im right, does this efectivly raise the ports on the serval and increase the RPM level when the torque comes in or does it over come the issue with the extra 3mm on the stroke?
Reason for asking is that i will be running that combination with 34mm carbys, +4timing and FMF fattys with 22cc domes. Just awaiting the cut domes.
