BellicoseBanshee Posted May 30, 2009 Report Posted May 30, 2009 Nothing, domes are kind of important... EDIT: Are you wanting to know what an aftermarket head with stock cc domes will do? Quote
dirtydownunder Posted May 30, 2009 Report Posted May 30, 2009 its like trying to eat without a jaw hahah. Quote
black sunshine Posted May 30, 2009 Report Posted May 30, 2009 One would think there would be better cooling, but many gurus on here say otherwise. So if you were not looking to change compression, your money would be better spent elsewhere..... Quote
BellicoseBanshee Posted May 30, 2009 Report Posted May 30, 2009 It's like trying to eat without a jaw. hahaha. :beer: Quote
DallasGDub Posted May 30, 2009 Report Posted May 30, 2009 One would think there would be better cooling, but many gurus on here say otherwise. So if you were not looking to change compression, your money would be better spent elsewhere..... If your bike had one like this, you could hold it WOT and be able to put your hand on the pipe at the same time. Quote
Ineedmoney Posted May 30, 2009 Author Report Posted May 30, 2009 NO what im saying is my friend said i should put a cool head on my bike. Do i need domes with the cool head, or can i jus tput the cool head on it. If i can will it do anything for power or anything on my bike. I have a cool head and dont know what to do wiht it. Quote
#1JUANstunna Posted May 30, 2009 Report Posted May 30, 2009 Domes go inside of the cool head and they are what makes your bike have more or less compression depending on what does you have. The domes are interchangable depending on what your application is. Quote
black sunshine Posted May 30, 2009 Report Posted May 30, 2009 If your bike had one like this, you could hold it WOT and be able to put your hand on the pipe at the same time. I thought what he was asking was if a coolhead was beneficial if you were not going to change compression. Quote
DallasGDub Posted May 30, 2009 Report Posted May 30, 2009 I know Blacksunshine, I was just messing around. :biggrin: Domes are what makes the coolhead a "head". It is a 3 piece system, domes, top and bottom plate. All 3 parts are a must. It replaces your old head. Your old head has domes built into it and is all 1 piece. Water flows around the top of the head to cool it off. Same as stock, only the water chambers are bigger and it is all billet so it runs cooler. Now the size of the domes are up to you and the mods, gas, and what you intend to run. Most go with 21cc domes. This is better than stock, but still safe in most areas for compression. If you do not plan on getting your motor worked, and you have not reason to change compression often. The alternative is have your stock head decked/shaved to drop the compression. It runs 50-80 bucks in most cases. IMO it is worth buying a cool head. Even for simple mods like timing, heat is added and the cooler the head, the better. Go with the NOSS Head. No changing out heads bolts. Quote
