gst_r Posted May 30, 2009 Author Report Posted May 30, 2009 Sorry I have to correct you on that one. Cold air does not expand greater than hot air. Its all the same air. Where the difference lays is that cold air is more dense than hot air so it takes up less space than the same amount of hot air. So the reason cold air makes a "bigger bang" is because you can fit/force more cold air in the same amount of space than you can of hotter air. Since there is more air in the same amount of space there is obviously more oxygen. Which is the reason their is a bigger bang. Not because it expands greater lol x2 on this..!! Quote
Misssppelllleddd Posted May 30, 2009 Report Posted May 30, 2009 Pump gas is Pump gas dont let any advertisements tell you different. I guess I dont see how enriching fuel with a Non Flamable, Non Oxidizing, Inert gas improve performance. I thought the whole idea of getting better performance was to get fuel in to the cylinder along with Oxygen wich suports combustion vs Nitrogen which doesnt. Very true but I've burned out my rings from using fuel with 10% ethanol added to it. At least thats what I think did it. Quote
dirtydownunder Posted May 31, 2009 Report Posted May 31, 2009 Sorry I have to correct you on that one. Cold air does not expand greater than hot air. Its all the same air. Where the difference lays is that cold air is more dense than hot air so it takes up less space than the same amount of hot air. So the reason cold air makes a "bigger bang" is because you can fit/force more cold air in the same amount of space than you can of hotter air. Since there is more air in the same amount of space there is obviously more oxygen. Which is the reason their is a bigger bang. Not because it expands greater lol that cold air doesnt stay dense for ever, when it goes bang its expands with all that oxygen, more so than hot air. its the same thing, your saying its dense (which it is) im saying it expands greater (becuase it does). Quote
okbeast Posted June 1, 2009 Report Posted June 1, 2009 that cold air doesnt stay dense for ever, when it goes bang its expands with all that oxygen, more so than hot air. its the same thing, your saying its dense (which it is) im saying it expands greater (becuase it does). Maybe you mean since there is more air in the cylinder then it expands "more" causing a bigger/hotter explosion. Quote
