oh, shoot, you said pro reeds, not power reeds. and i was thinking carbon fibre. guess i needed to pay closer attention to the terms. was tired as fuck. working nights right now. actually just got off about an hour ago. my bad, sorry :whistling:
Them are dual stage power reeds... The pro series use a carbon fiber top reed and a epoxy lower.
yah, i'm running the powers right now. budgeting for the pro's or another mid-top reed. gotta pay off my new 20's, and daughters' karate first. 80 hrs/week and still not enough, lol
I've ran both and didn't notice much difference. They're both dual stage. I would have to assume as long as tension is the same on the coupler reed. The only difference would be the carbon would have a longer life span. The ends did fray and chip rather quickly on the power reeds I had.
Pro series is a good reed though.. Ran them on my blaster for years!
As mikenick said, porting your stock cages and putting some 2 stage reeds on, carbon tech if its a low to mid bike will work good, I have had good luck with this and depending on application performs as well as VF3's because the V-forces are more of a top end mod
I was just gonna run my stock cages on my new 4mil stock cylinder setup, but I asked Cameron to throw a set of vf3's on to see the difference, and I gained from bottom to top a minimum of 2HP through the range. It made more of a HP difference in the low to mid RPM range.
how are boysen rad valves?
I run them on my bike and I like them. But Ive never run anything else except for stockers so I don't have much to compare them too. I don't think I gained any power, but the throttle seems like it has a little more pep. I wouldnt pay 200 beans for them again, I dont think theyre worth that much.
I just bought a set on ebay for 43$ so i figured i would try them. I'm gettin a mx/hardcore port job done at hjr right now so I wanted to get away from stock without playin my guitar on the street
:yelrotflmao: I like the guitar quote. Ive always ran them on my YZs, and never anything else. I don't think reeds are ever going to make a HUGE difference, but for $43 you can't go wrong. I think theyre worth that.
