Cub cylinders are cast for which ever stroke you want to use. If you want a 4mm stroke, you will buy the 4mm cub cylinder. You will need big bore domes, not recessed domes.
I am not familiar with Fireball Racing heads, but it should work on a cub cylinder as long as the head will accept big bore domes.
ok, im starting to get it. i call the guy and he said he has domes that will fit a pro design, but im unsure if they will fit in a fireball. i have a set of pro designs so if all else fails i use the pro designs on my new engine
