ok well for quite some time now in high rpm i have a problem shifting. from 3rd up it will not shift at high rpm i have to let the motor die down clutch it and then shift. its iritating me i just replaced the shifter forks with mint ones. the adjusting screw is right theres about 1 mm up and down gap. i have grinded down the shift start for smoother shifting i cannot figure this out what could it be ?? o and its a F.A.S.T clutch with heavy springs.
could it be that the basket bushings are shot and it moves about a half inch ?
what are some things to check ???
because its to the point were i have a chunk of skin missing off the top of my toe from trying to slam it into gear
O it doesnt do it when the bike is cold that i have noticed that once it starts getting hot it goes retarded
