robert0762 Posted May 17, 2009 Report Posted May 17, 2009 (edited) I usually ride in the woods and dirt roads but today i hit some asphalt and as soon as I hit 2 gear i blew my chain apart . i WILL BE REPLACING SPROCKETS ALSO .What is a good set to get. Also i am gonna get a case saver cause if i would have ruind my case i would be lost right now. Begining of the summer and no banshee.....not a good thing Edited May 17, 2009 by robert0762 Quote
AKheathen Posted May 17, 2009 Report Posted May 17, 2009 i'd get an x-ring, but just look around, and pay attention to the tensil strength. if it's not listed, then it's too low. shoot for at least 7,000lbs. just my .02 Quote
robert0762 Posted May 17, 2009 Author Report Posted May 17, 2009 D.I.D. aND PRIMARY DRIVE R THEY GOOD BRANDS or ne thing rated above 7000 Quote
BellicoseBanshee Posted May 17, 2009 Report Posted May 17, 2009 D.I.D. o-ring chain, sidewinder sprockets, and the TM Designworks case saver. The largest sprocket that will fit with the TM designworks case saver is 15 tooth. Try to work your gearing around a 15 tooth front, for the case saver will work the best if the chain cannot bind up between the case saver and the sprocket. Maybe a large rear sprocket will cause clearance issues with a skid plate, but larger sprockets, front and rear, will greatly increase the life of the chain and sprockets... Quote
