fitz18 Posted May 9, 2009 Report Posted May 9, 2009 Hi all, Like the title says I have bubbles in my trans oil. You can see them all over the dip stick. Is this a problem or is it good to ride? whats the cause and cure for this? Thanks guys :biggrin: Quote
ATVdragger Posted May 9, 2009 Report Posted May 9, 2009 Hi all, Like the title says I have bubbles in my trans oil. You can see them all over the dip stick. Is this a problem or is it good to ride? whats the cause and cure for this? Thanks guys :biggrin: Run it.. Having clear bubbles is normal. Unless they are white in color. That means you have water in the tranny oil. Quote
jasons Posted May 10, 2009 Report Posted May 10, 2009 Run it.. Having clear bubbles is normal. Unless they are white in color. That means you have water in the tranny oil. it depends on when you check you oil. if you check your oil right after you run it then you will have bubbles in the oil. if youlet it sit for a few it should be ok. or you have way to much oil in it an dit is foaming. Quote
