I having trouble with my armature on my banshee, it wont come out of the case. the other day the clutch lever went limp it had no tension on it what so ever. so i pulled the cover off the side to check out the clutch the clutch ball welded its self to the push rod. i havent tried to get the pushrod out yet but i know for sure my armature wont come out the case, im just wondering if i have to split the case or not or if i can just leave it alone and ust buy a new clutch ball and pancake bearing
sometimes when you weld the pushrod assembly up it will mar the pushrod surface of the armature creating a burr that wont allow you to reamove the arm without galling up the bore where tha arm rides.
i have removed them before with minimal scarring of the bore but the correct way to do it without chewing anything up is to split the cases and grind off the burr before removal of the arm.
that being said the main surfaces that the arm ride on are the small pin on the bottom that seats into the lower case half and the bearing at the top of the upper case so if it's not too bad you can try and work it out...
like most things on here it's kind of hard to form an opinion without having it in front of me...
is there a fix to this problem? just wondering so it dont happen to me in the future.
I would say that besides installing a pancake bearing, you can also put in a new ball and rod as well. Just to play it safe. I know RagunCajon put in the pancake bearing, but the ball and rod had imperfections. It ended up welding anyways.
Here is a pics of what swrbansheeboy is talking about. (Pics from LS1Inferno from when he helped me)
so what would happen if i just leave the pushrod an armature in the case and just replace the clutch ball and put a pancake bearing in and call it good. cause im not sure if this is true but somebody told me if i dont replace the pushrod it could weld it self to the shaft it runs through and and destroy the trans
Split the cases and do it right the first time!! Replace everything, it is way cheaper than having to split the cases and do it all again in a few rides if not minutes. You can probably clean up and reuse the clutch actuator, but the ball is like a buck and the rod is cheap!! Pancake bearings are a must on all of my bikes!! I took the short cut once and missed a big weekend over a few bucks and a little work!! Never again!! Good luck!! Z
Edited by zachass9
k thanks looks like ill be doing that this weekend who sells the best pancake bearing
what all is involved in doing so, do you have to split the cases to change out the pancake bearing rod and ball? wheres the best place to buy these?
no the pancake bearing is easy to install all you have to do is pull the clutch cover off and u will see where it has to go it replaces the adjuster nut on the clutch pressure plate. its hard to explain without pics but it comes in a kit with a new nut and a flat needle bearing
