kubitza123 Posted May 4, 2009 Report Share Posted May 4, 2009 Finally got to run my quad for the first time with the new chassis etc. So far best time of 6.6 at 100.24 stock cy 4 mill on alky non triple ported by JEFF at F.A.S.T With 1.55 60ft time so once the 60ft's around 1.4 maybe shade better like it should be quad should hit 6.4 on motor Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 4, 2009 Report Share Posted May 4, 2009 I run pretty much the same piece on gas,whats your gearing at for the 1/8 I might be forced to run the 1/8th against someone and my bike is set for the 1/4 Quote Link to comment Share on other sites More sharing options...
kubitza123 Posted May 4, 2009 Author Report Share Posted May 4, 2009 right now 18/40 with a 5 speed trans pretty much perfect for mine Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 4, 2009 Report Share Posted May 4, 2009 I run the 17-40 with straight cut gears in the taller ratio with a sixth gear for the 1/4,I think im gonna be short on the 1/4 now.I just put oofs on it with the overide and she boogies through the gears Quote Link to comment Share on other sites More sharing options...
kubitza123 Posted May 4, 2009 Author Report Share Posted May 4, 2009 Yeah not sure mines got stock ratio straight cut gears so tuff to say then. Beens you have a 6 speed you can probably gear it lower than mine but the higher the better if the powers there . When i run threw the 1/8 right now my quads exactly wide open. May go with higher gearing soon quad has the power to pull more. When i add the NOS i know i'll go to maybe a 19 in the front or 38 in the rear. Quote Link to comment Share on other sites More sharing options...
grizzly700 Posted May 4, 2009 Report Share Posted May 4, 2009 dont mean to jack thread but wats does your bike run in the 1/4 sleeper06? Quote Link to comment Share on other sites More sharing options...
kubitza123 Posted May 4, 2009 Author Report Share Posted May 4, 2009 normally from what i see posted if you run 6.5's or lower usually with the right gaering you can run mid-high 10's Quote Link to comment Share on other sites More sharing options...
grizzly700 Posted May 6, 2009 Report Share Posted May 6, 2009 thanks Quote Link to comment Share on other sites More sharing options...
stroking Posted May 7, 2009 Report Share Posted May 7, 2009 i have a friend run 18/33 on 18"hosssiers and he can barely get through the 1/8mile without topping out its a stock cylinder 68mm/longrod 4mill....with triple ported cylinders it does have a override 1-5 it run 6.70's Quote Link to comment Share on other sites More sharing options...
ATVdragger Posted May 9, 2009 Report Share Posted May 9, 2009 i have a friend run 18/33 on 18"hosssiers and he can barely get through the 1/8mile without topping out its a stock cylinder 68mm/longrod 4mill....with triple ported cylinders it does have a override 1-5 it run 6.70's Hey, Stroking. Tell your friend to get some American Racer with 63" rollout and that will help alot. Those 18" have a too small of a rollout. Thats slowing him down alot. Quote Link to comment Share on other sites More sharing options...
stroking Posted May 11, 2009 Report Share Posted May 11, 2009 Hey, Stroking. Tell your friend to get some American Racer with 63" rollout and that will help alot. Those 18" have a too small of a rollout. Thats slowing him down alot. i was thinking he's pretty fast.......from what i've test smaller tires with taller gearing give better times than bigger tires and lower gearing because bigger tires carrier more weight. Quote Link to comment Share on other sites More sharing options...
