MAICK Posted May 4, 2009 Report Posted May 4, 2009 um i heard that for some reason oil was good for a motor. has anyone else ever heard that. ok im done joking around. my real question is i got a little bit of play in my handle bars. if you just wiggle them like your turning. they got about a half of an inch of play. does that mean i need some new tie rod ends. it looks like that is where all the play is. but i didnt know if that was normal for a banshee. Quote
shee4speed Posted May 4, 2009 Report Posted May 4, 2009 Crisco for the oil.you have play in the tierod ends? Quote
MAICK Posted May 4, 2009 Author Report Posted May 4, 2009 Crisco for the oil.you have play in the tierod ends? yeah pretty much if you turn the handle bars an half inch left or right you would not seen any movement in the tires. but you can see the tie rod ends moving (the little ball joints on the tie rods. it has been like that since i bought it. but my yfz is real tight, and there is no play. Quote
shee4speed Posted May 4, 2009 Report Posted May 4, 2009 you can replace the balljoints and see if its all good. Quote
