snoxrage Posted April 30, 2009 Report Share Posted April 30, 2009 I came across the Kicker rebuild awhile ago. It tells you what size o-rings, ball, and spring to buy. Ive been searching for an hour now. Can anyone help me out? I just don't want to rattle anymore... Quote Link to comment Share on other sites More sharing options...
shee4speed Posted April 30, 2009 Report Share Posted April 30, 2009 Click here and scroll down Quote Link to comment Share on other sites More sharing options...
DallasGDub Posted April 30, 2009 Report Share Posted April 30, 2009 I foudn this on here, saved it to my Banshee docs. The Holyman kicker fix. Here's what you do... You go to the hardware store {Sears, Ace etc.} and buy... 1- .25" steel ball bearing 1- M6x40 allen head screw {I'll give instructions on how to find the right one later} 1- #8 spring 1- #2 spring and 1- #86 spring A- Take the kicker off the bike and clamp it in the vice. B- Remove the kicker lever. If the screw is stripped, drill a 3/16 hole into the OTHER end of the screw not into the head of the screw. You should be able to use a screw driver or a chisel and work the screw loose now. C- Be careful to save the stock spring that is behind the ball. {if it's still there} D- Use a Dremel tool to open up the hole in the post big enough to fit the .25" ball into it. DO NOT use force to fit the ball into the hole, you'll NEVER get it out. E- smear some grease into the hole and then put in the original spring {or one of the springs listed above. You will need to cut it down if you use one of the hardware store springs} F- smear more grease onto the post that the lever slips on to. G- Take the cone shaped spring and cut it in half and put it on top of the post with the small end facing up. Make sure the spring isn't so wide that it is wider than the post. If it is, cut it down some more or bend in the part that sticks out. H- Slide the kick lever onto the post and screw in the allen screw to hold it on. ******** Here's where you need to know how to get the right allen screw. *********** When you go to the hardware store, take the kicker with you. You want to buy an allen screw that has a shank {the unthreaded part} that is long enough so that NO threads are in the groove area of the post. To find this out, thread in the screw into the kick lever all the way. Then look into the hole in the bottom of the lever and see if there are any threads visible in the hole. If not, then you have the right one. I- After the kicker is completely assembled, make sure it rotates smoothly. Then cut off the rest of the allen bolt that's sticking out and re-install the kicker. It should last a lifetime. Some guys will re-install an O ring. Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted April 30, 2009 Report Share Posted April 30, 2009 I went to the local hardware store, and bought an o-ring with the same inside diameter, but thicker, for $0.99. Works like a dream. Haven't heard that rattle since. Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted April 30, 2009 Report Share Posted April 30, 2009 Click here also, FAST Racing is a site sponsor and great to deal with. Quote Link to comment Share on other sites More sharing options...
Rodneya Posted April 30, 2009 Report Share Posted April 30, 2009 I went to the local hardware store, and bought an o-ring with the same inside diameter, but thicker, for $0.99. Works like a dream. Haven't heard that rattle since. I just put in 2 o rings and used a vice to get it squeezed down enough to get the screw back in. It works great. Looking for new springs and stuff just seemed like too much work to achieve the same result. Quote Link to comment Share on other sites More sharing options...
snoxrage Posted April 30, 2009 Author Report Share Posted April 30, 2009 Thanks for the help guys! Quote Link to comment Share on other sites More sharing options...
