shee23 Posted April 26, 2009 Report Posted April 26, 2009 im trying to put a new crank in but im havin trouble with the main drive gear nut on the crank and the nut in the clutch. i tried putting a rag in the teeth between the gears but it just eats up the rag. that damn thing is on there so wat should i do. thanks Quote
AWR Posted April 26, 2009 Report Posted April 26, 2009 put a penny in the gears and hit it with an impact....peace Quote
RUDEDAWG Posted April 26, 2009 Report Posted April 26, 2009 Use the same rag and an air impact to get the nut loose. Quote
shee23 Posted April 26, 2009 Author Report Posted April 26, 2009 put a penny in the gears and hit it with an impact....peace im gonna have to get one Quote
278 Posted April 26, 2009 Report Posted April 26, 2009 Yeah man use a penny you should be able to atleast get the crank nut off but the clutch will probably need an impact for Quote
locogato11283 Posted April 26, 2009 Report Posted April 26, 2009 use something more solid than a rag but not something that will damage the gears. as for the clutch nut, an impact works best. use something that wont damage the clutch basket to keep it from spinning. are you using an impact? if so this stuff should be easy. if not, good luck. Quote
sheeban Posted April 26, 2009 Report Posted April 26, 2009 use something more solid than a rag but not something that will damage the gears. as for the clutch nut, an impact works best. use something that wont damage the clutch basket to keep it from spinning. are you using an impact? if so this stuff should be easy. if not, good luck. I used an old license plate bent in half with a impact worked perfect with no damage Quote
shee23 Posted April 26, 2009 Author Report Posted April 26, 2009 I used an old license plate bent in half with a impact worked perfect with no damage thanks for the ideas Quote
TNTS355 Posted April 26, 2009 Report Posted April 26, 2009 put a penny in the gears and hit it with an impact....peace If you use a penny you can get by with not using an impact. Or you can spend a few $$$ and buy a strap wrench and you can hold either side. Quote
RUDEDAWG Posted April 26, 2009 Report Posted April 26, 2009 Try one of these if you dont have an air compressor, harbor freight and they work like a dream. Every banshee owner needs one of these. :thumbsup: Quote
