im building a 4 mil stock cylinder motor. i was wondering should i go with a duneable override trans or lock out clutch? im runnin low on funds so i cant do both. which one would be better for duneing? thanks!!!!!!!!
im gonna say go with the duneable overide. since you have the cases apart already you might better do everything right inside there the first time so you dont hafta go back later and split your cases again. then when you get some money saved up a lockout is a quick and easy mod to do.
what he said :thumbsup:
