Thoughtshewas18 Posted April 17, 2009 Report Posted April 17, 2009 Honestly it could be more than 6 months. Other than changing out the old oil, what else should I touch up? Quote
Thoughtshewas18 Posted April 17, 2009 Author Report Posted April 17, 2009 Should I have emptied the gas out? Quote
NitroTate Posted April 17, 2009 Report Posted April 17, 2009 Yeah I'd probably change out the gas and oil, make sure the plugs are in tight, check radiator fluid level, lightly kick it over a few times to get things moving again and then crank her up. Quote
Thoughtshewas18 Posted April 17, 2009 Author Report Posted April 17, 2009 Thanks dude. Best way to drain the tank? Just let it drain out the side? Quote
vulvafan537240 Posted April 17, 2009 Report Posted April 17, 2009 i turn my petcock off, remove the tank and turn it upside down to get it all out Quote
banshee_terror_ Posted April 17, 2009 Report Posted April 17, 2009 (edited) or you rip the gas line off and turn it on resurve. let it drip out that way. also drain the carbs of any bad gas and while your at it clean them Edited April 17, 2009 by banshee_terror_ Quote
Fireroad Express Posted April 18, 2009 Report Posted April 18, 2009 i'd also clean the jets in your carbs. gas does not take long to break down when its being stored. the gas turns to a varnish and coats the inside of your jets reducing thier flow. this may burn you down if the are clogged badly. i've seen this happen quite a few times. Quote
